You have to find how much data and for what it is used.
Maybe look into the asm code,
May you have to choose another Avr.
Other members may assist you better here.
I built voltmeter on Printed Circuit Board , it runs successfully but some flickering appears in the digits not smooth
displaying.What should I do for repair it?
The answer fir the flickering is in my posts 23 and 36.
You update the disply values too often.
Just use the "flag" solution and see what happens....
I only had a short look to your code:
* sometimes there is portd used for display, sometimes portc. Some more remarks in your code could help us to understand what it does / should do. What is the multiplex rate.
* Did you check the timing with all your code. Check how often per second runs the one and the other isr? What runtime have the two isr?
