Three phase motor drive IGBT power section help
maxim10373
Helo,
Here I want to remove the IGBT and put a three phase mosfet bridge circuit. also want to use the same driver.
what you say?
Ajitkumar
  • pwm1.pdf
i would say , i will work , assuming yo choose mosfets with high voltage rating that suits the application .
usually mosfets and IGBTs share the same drivers . for example : ir2110 and similar Ics
