Berend Kunze
Newbie level 6
Hello, everyone.
You need to build a circuit.
The voltage generated by the TEG is between 0 and 1V.
When it is 0~0.5v, power must be guaranteed to device A, and between 0.5~1V, power must be supplied to device B.
The power generated by the TEG is up to 1W.
How should I configure the controller to perform this action?
I'm trying to solve it by using an op amp comparator.
However, it is not possible to select the correct element.
If satisfied through the conversation, a certain payment will be made
thanks.
thanks.
