monahanz
Junior Member level 1
- Joined
- Nov 11, 2013
- Messages
- 19
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- San Ramon CA
- Activity points
- 1,490
I have been using .vhd files from Open Cores with good success in Intel's Quartus.
However in many cases I reach a roadblock. In all such cases there are multiple files to compile.
For example:-
I would like to make a .bdf module from the “Simple UART for FPGA” by Jakub Cabal.
The UART.vhd root file has at the start
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.MATH_REAL.ALL;
all of which are fine with Quartus.
But down a few lines there is:-
os_clk_divider_i : entity work.UART_CLK_DIV
generic map(
DIV_MAX_VAL => OS_CLK_DIV_VAL,
DIV_MARK_POS => OS_CLK_DIV_VAL-1
There is a separate file “UART_clk_div.vhl’ in the same directory (which compiles fine BTW).
I get this a lot. Quartus gets hung up on finding the entity “work”
What do I need to add to get Quartus to include files with “work” attached?
Thanks in advance
John
For example:-
generic map(
Thanks in advance
John
