The "work" entity is Quartus (Lite V18.0)
monahanz
Junior Member level 1
San Ramon CA
I have been using .vhd files from Open Cores with good success in Intel's Quartus.
However in many cases I reach a roadblock. In all such cases there are multiple files to compile.
For example:-
I would like to make a .bdf module from the “Simple UART for FPGA” by Jakub Cabal.
The UART.vhd root file has at the start
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.MATH_REAL.ALL;
all of which are fine with Quartus.
But down a few lines there is:-
os_clk_divider_i : entity work.UART_CLK_DIV
generic map(
DIV_MAX_VAL => OS_CLK_DIV_VAL,
DIV_MARK_POS => OS_CLK_DIV_VAL-1
There is a separate file “UART_clk_div.vhl’ in the same directory (which compiles fine BTW).
I get this a lot. Quartus gets hung up on finding the entity “work
What do I need to add to get Quartus to include files with “work” attached?
Thanks in advance
John
How do I do that?
--- Updated ---
Never mind I figured out how to do it:-
(Main menu, add/remove files in project)
Thanks so much
John
"Work" in this context is not an entity, it means "current working library" in vhdl. Usually this will be the library you're compiling the file into.
