The thinnest UHF RFID tag antenna
streamlet
Full Member level 3
As far as I know, the published smallest thickness is 1.52 mm, which is a PIFA-type antenna made on Taconic RF-35 substrate. Have anyone seen any UHF tag antenna thinner than this?
Libor124
Junior Member level 1
Hi, yes I have on my hand the UHF on metal tag with thickness 1.00mm, the reading distance on metal was 2feets(50cm) 2W ERP
FvM
Super Moderator
Staff member
Bochum, Germany
Yes, you are right for PIFA. I was thinking of a patch antenna.
streamlet
Full Member level 3
may I know the horizontal size of the metal tag?
Libor124
Hi ,
I have for your small update, the smaller UHF tag on metal has the size 15x15x1,5mm, what is exciting , the tag is possible read with output power of a reader 100mW
WimRFP
Advanced Member level 5
Netherlands
Hello FvM and Volker
From my experience PIFA over ground is half a patch (shorted quarter wave resonator instead of half wave), so same rules apply as for patch antennas. Maybe you have some other structure in mind?
