The thinnest UHF RFID tag antenna
streamlet
Full Member level 3
As far as I know, the published smallest thickness is 1.52 mm, which is a PIFA-type antenna made on Taconic RF-35 substrate. Have anyone seen any UHF tag antenna thinner than this?
Hi, yes I have on my hand the UHF on metal tag with thickness 1.00mm, the reading distance on metal was 2feets(50cm) 2W ERP
Yes, you are right for PIFA. I was thinking of a patch antenna.
may I know the horizontal size of the metal tag?
Hi ,
I have for your small update, the smaller UHF tag on metal has the size 15x15x1,5mm, what is exciting , the tag is possible read with output power of a reader 100mW
Hello FvM and Volker
From my experience PIFA over ground is half a patch (shorted quarter wave resonator instead of half wave), so same rules apply as for patch antennas. Maybe you have some other structure in mind?
