W6DSR
Newbie
I want to combine two identical UHF antennas with a 3 dB combiner, and then feed that signal to a very low noise amplifier for an improvement in SNR. I am also considering using two matched very low noise amplifiers (close phase characteristics, and gain matched), one for each antenna, and then combining the amplifier outputs with the same combiner. I've been told that using two amplifiers and then combining signals will not yield an improvement in SNR vs combining the antennas before a single amplifier. Could someone explain why this is true?
Thanks,
-Doug, W6DSR
Thanks,
-Doug, W6DSR
