the size is not big enough to place all pads- need help
handsome
Junior Member level 3
die size staggered pad
Hi,all
In my project, die size is not big engouth to place all pads which use wire bongding.
How can I slove this problem?I dont want to add the die size.
Thx.
jbeniston
Advanced Member level 1
die size and pad numer
Use staggered pads instead of inline pads if you have them. Use flip chip instead of wire bond.
handsome
Thx.
I have used staggered pads.
Flip chip will need more money. And I am not familiar with the FC‘s backend flow。
Can you tell me the difference between the nomal wire bonding PR flow and the FC's PR flow?
Added after 1 minutes:
Can anyone explain the "multi tier packages"?
hiral.kotak
Full Member level 2
Re: die size and pad numer
staggered pad approach is the good one. u can also use radially staggered pad placement.
thanks..
HAK..
