samuel
Full Member level 3
hello everyone,
I had designed a chip. in the normal temperature, the test of the chips are ok; but after higher temperature(125 ℃) and low temperature(-55 ℃) tests , a problem happens to some of twenty chips , that is, the current of the wrong chips become larger. I had check the wrong chips and found ESD circuit of the vdd pad of the wrong chips have the overflow phenomena.
Why? Anyone can explain this phenomena? thanks.
