jasonkee111
Junior Member level 3
Hi. I generated 1 sine wave (24bit output[23:0]). In order to control the amplitude, the output multiply with a ratio(fixed point multiplier). for fix point multiplication,
verilog declaration
sin [23:-10]//zero pad
ratio [0:-10]
result_mult [24:-20]
Asin <= result[23:0]
After the simulation, i realised that the THD+N is 74(-80db to -6)(the THD+N of sine wave without multiplier is infinity).
May i know what is the problem to cause this? How to reduce this?
Any better way to control the amplitude? using floating point mult?
Besides, why the result_mult have to be [24:-20] instead of [23:-20]? if use [23:-20]. the result_mult always 2 times less than the correct one.
thanks a lot
verilog declaration
ratio [0:-10]
thanks a lot
