mr_W
Junior Member level 2
This is the display I'm about to use in my project - it's Formike's KWH102KQ03-F02, for which I got datasheet earlier (as they are reorganizing their website, and lots of old stuff is not yet online). (**broken link removed**).
uC that I'll be using is NXP's LPC2478, and I have also Olimex developer board for testing. Dev board also has TFT attached, so there is at least some reference design.
Now about the problem - it is the POL signal at pin #1 and CKV at #4.
POL is confusing in that sense, that in Olimex board (and their TFT) it is output pin and as far as I understood from schematics ( **broken link removed** ) is used for adjusting VCOM voltage depending on polarity - that is neat thing. However, on Formike's display, it is marked as INPUT. Am I supposed to take care about driving it correctly (invert it every frame?), or the datasheet is wrong? There are so many similar displays and datasheet files that look more/less the same, but with subtle differences - like this pin which is on some also marked as OUTPUT.
For CKV pin, I'm completely clueless.
And oh, there are Gamma correction inputs, but I'm not concerned about them. I'll just have them all on fixed voltage. What can I do
