testing bits in vhdl within if statement
rameshrai
Full Member level 3
Full Member level 3
is there any better way to write the following in vhdl:
if ((x(0)='0' or x(1)='0' or x(2)='0' or x(3) = '0') and (y(0)='0' or y(1)='0' or y(2)='0' or y(3) = '0')) then
thanks
There's nothing bad with the statement. But you can save some writing when
using VHDL2008 logical reduction operators
if NOT (AND x) AND (OR y) then
or logical reduction functions from syn_misc library
if nand_reduce(x) AND or_reduce(y) then
Why not this:
if x /= "1111" and y /= "1111" then
It will synthesize to the same logic, but it can be different for simulation with 'X', 'Z' etc.
For vectors with the length specified with a generic, a constant should be used instead of the "1111" vectors:
constant c_all_ones : std_logic_vector(same range as x and y) := (others => '1');
if x /= c_all_ones and y /= c_all_ones then
This will work without VHDL 2008.
LaTeX Commands Quick-Menu:
