fanwel
Full Member level 3
Dear All,
I'm new in vhdl. I need help for tell me what the false in my code.
Below is my vhdl code where it can simulate successfully in Quartus.
LIBRARY ieee;
USE ieee.ALL;
ENTITY haar IS
PORT (
clock : IN bit;
-- Inputs
in1 : IN integer RANGE -127 TO 127;
in2 : IN integer RANGE -127 TO 127;
in3 : IN integer RANGE -127 TO 127;
in4 : IN integer RANGE -127 TO 127;
in5 : IN integer RANGE -127 TO 127;
in6 : IN integer RANGE -127 TO 127;
in7 : IN integer RANGE -127 TO 127;
in8 : IN integer RANGE -127 TO 127;
--Outputs
out1 : OUT integer RANGE -127 TO 127;
out2 : OUT integer RANGE -127 TO 127;
out3 : OUT integer RANGE -127 TO 127;
out4 : OUT integer RANGE -127 TO 127;
out5 : OUT integer RANGE -127 TO 127;
out6 : OUT integer RANGE -127 TO 127;
out7 : OUT integer RANGE -127 TO 127;
out8 : OUT integer RANGE -127 TO 127
END haar;
ARCHITECTURE haar OF haar IS
COMPONENT reg
PORT (
input : IN integer RANGE -127 TO 127;
clk : IN bit;
output : OUT integer RANGE -127 TO 127
END COMPONENT;
COMPONENT adddiv
PORT (
a : IN integer RANGE -127 TO 127;
b : IN integer RANGE -127 TO 127;
clk : IN bit;
c : OUT integer RANGE -127 TO 127
END COMPONENT;
COMPONENT difference
PORT (
clk : IN bit;
END COMPONENT;
SIGNAL out_r1, out_r2, out_r3, out_r4, out_r5, out_r6, out_r7,
out_r8, out_r9, out_r10, out_r11, out_r12, out_r13, out_r14,
out_r15, out_r16, out_r17, out_r18, out_r19, out_r20, out_r21,
out_r22, out_r23, out_r24 : integer RANGE -127 TO 127;
SIGNAL out_a1, out_a2, out_a3, out_a4, out_a5, out_a6, out_a7 : integer RANGE -127 TO 127;
SIGNAL out_s1, out_s2, out_s3, out_s4, out_s5, out_s6, out_s7 : integer RANGE -127 TO 127;
SIGNAL clk : bit;
BEGIN
-- Input to Register 1
r1: reg
PORT MAP ( in1, clk, out_r1 );
r2: reg
PORT MAP ( in2, clk, out_r2 );
r3: reg
PORT MAP ( in3, clk, out_r3 );
r4: reg
PORT MAP ( in4, clk, out_r4 );
r5: reg
PORT MAP ( in5, clk, out_r5 );
r6: reg
PORT MAP ( in6, clk, out_r6 );
r7: reg
PORT MAP ( in7, clk, out_r7 );
r8: reg
PORT MAP ( in8, clk, out_r8 );
-- Input to Add_Divide and Difference for stage 1
a1: adddiv
PORT MAP ( out_r1, out_r2, clk, out_a1 );
a2: adddiv
PORT MAP ( out_r3, out_r4, clk, out_a2 );
a3: adddiv
PORT MAP ( out_r5, out_r6, clk, out_a3 );
a4: adddiv
PORT MAP ( out_r7, out_r8, clk, out_a4 );
s1: difference
PORT MAP ( out_r1, out_r2, clk, out_s1 );
s2: difference
PORT MAP ( out_r3, out_r4, clk, out_s2 );
s3: difference
PORT MAP ( out_r5, out_r6, clk, out_s3 );
s4: difference
PORT MAP ( out_r7, out_r8, clk, out_s4 );
--Input to Register 2
r9: reg
PORT MAP ( out_a1, clk, out_r9 );
r10: reg
PORT MAP ( out_a2, clk, out_r10 );
r11: reg
PORT MAP ( out_a3, clk, out_r11 );
r12: reg
PORT MAP ( out_a4, clk, out_r12 );
r13: reg
PORT MAP ( out_s1, clk, out_r13 );
r14: reg
PORT MAP ( out_s2, clk, out_r14 );
r15: reg
PORT MAP ( out_s3, clk, out_r15 );
r16: reg
PORT MAP ( out_s4, clk, out_r16 );
-- Input to AddDiv and Difference for stage 2
a5: adddiv
PORT MAP ( out_r9, out_r10, clk, out_a5 );
a6: adddiv
PORT MAP ( out_r11, out_r12, clk, out_a6 );
s5: difference
PORT MAP ( out_r9, out_r10, clk, out_s5 );
s6: difference
PORT MAP ( out_r11, out_r12, clk, out_s6 );
--Input to Register 3
r17: reg
PORT MAP ( out_a5, clk, out_r17 );
r18: reg
PORT MAP ( out_a6, clk, out_r18 );
r19: reg
PORT MAP ( out_s5, clk, out_r19 );
r20: reg
PORT MAP ( out_s6, clk, out_r20 );
r21: reg
PORT MAP ( out_r13, clk, out_r21 );
r22: reg
PORT MAP ( out_r14, clk, out_r22 );
r23: reg
PORT MAP ( out_r15, clk, out_r23 );
r24: reg
PORT MAP ( out_r16, clk, out_r24 );
--Input to AddDiv and Difference for stage 3
a7: adddiv
PORT MAP ( out_r17, out_r18, clk, out_a7 );
s7: difference
PORT MAP ( out_r17, out_r18, clk, out_s7 );
--Input to Register 4
r25: reg
PORT MAP ( out_a7, clk, out1 );
r26: reg
PORT MAP ( out_s7, clk, out2 );
r27: reg
PORT MAP ( out_r19, clk, out3 );
r28: reg
PORT MAP ( out_r20, clk, out4 );
r29: reg
PORT MAP ( out_r21, clk, out5 );
r30: reg
PORT MAP ( out_r22, clk, out6 );
r31: reg
PORT MAP ( out_r23, clk, out7 );
r32: reg
PORT MAP ( out_r24, clk, out8 );
END haar;
The problem is when I make the testbench for the above code, it not generate the outputs. But, the input is correct. Below is my testbench code. Anyone can tell me what I', missing please. Many thanks.
library IEEE;
use IEEE.Std_logic_1164.all;
use IEEE.Numeric_Std.all;
entity haar_tb is
end;
architecture bench of haar_tb is
-------------Component Declarations---------------
component haar
PORT (
clock : IN bit;
end component;
--------------Signal Declarations-----------------
signal clock: bit;
signal in1: integer RANGE -127 TO 127;
signal in2: integer RANGE -127 TO 127;
signal in3: integer RANGE -127 TO 127;
signal in4: integer RANGE -127 TO 127;
signal in5: integer RANGE -127 TO 127;
signal in6: integer RANGE -127 TO 127;
signal in7: integer RANGE -127 TO 127;
signal in8: integer RANGE -127 TO 127;
signal out1: integer RANGE -127 TO 127;
signal out2: integer RANGE -127 TO 127;
signal out3: integer RANGE -127 TO 127;
signal out4: integer RANGE -127 TO 127;
signal out5: integer RANGE -127 TO 127;
signal out6: integer RANGE -127 TO 127;
signal out7: integer RANGE -127 TO 127;
signal out8: integer RANGE -127 TO 127 ;
signal input: integer RANGE -127 TO 127;
signal clk: bit;
signal output: integer RANGE -127 TO 127 ;
constant clock_period: time := 10 ns;
signal stop_the_clock: boolean;
begin
---------------Component Instantiation--------------
uut: haar
port map ( clock => clock,
in1 => in1,
in2 => in2,
in3 => in3,
in4 => in4,
in5 => in5,
in6 => in6,
in7 => in7,
in8 => in8,
out1 => out1,
out2 => out2,
out3 => out3,
out4 => out4,
out5 => out5,
out6 => out6,
out7 => out7,
out8 => out8 );
stimulus: process
begin
---------------------First Test------------------
in1 <= 18;
in2 <= 5;
in3 <= 1;
in4 <= 9;
in5 <= 13;
in6 <= 6;
in7 <= 2;
in8 <= 3;
wait for 50ns;
---------------------Second Test------------------
in1 <= 10;
in2 <= 2;
in3 <= 3;
in4 <= 4;
in5 <= 15;
in6 <= 7;
in7 <= 13;
in8 <= 8;
wait for 50ns;
---------------------Third Test--------------------
in1 <= 1;
in2 <= 3;
in3 <= 11;
in4 <= 8;
in5 <= 15;
in6 <= 4;
in7 <= 6;
in8 <= 13;
wait for 50ns;
stop_the_clock <= true;
wait;
end process;
clocking: process
begin
while not stop_the_clock loop
clock <= '1', '0' after clock_period / 2;
wait for clock_period;
end loop;
wait;
end process;
end;
LIBRARY ieee;
USE ieee.ALL;
ENTITY haar IS
PORT (
clock : IN bit;
-- Inputs
--Outputs
END haar;
COMPONENT reg
PORT (
clk : IN bit;
END COMPONENT;
COMPONENT adddiv
PORT (
clk : IN bit;
END COMPONENT;
PORT (
clk : IN bit;
END COMPONENT;
SIGNAL clk : bit;
BEGIN
r1: reg
r2: reg
r3: reg
r4: reg
r5: reg
r6: reg
r7: reg
r8: reg
a1: adddiv
a2: adddiv
a3: adddiv
a4: adddiv
s1: difference
s2: difference
s3: difference
s4: difference
r9: reg
r10: reg
r11: reg
r12: reg
r13: reg
r14: reg
r15: reg
r16: reg
a5: adddiv
a6: adddiv
s5: difference
s6: difference
r17: reg
r18: reg
r19: reg
r20: reg
r21: reg
r22: reg
r23: reg
r24: reg
a7: adddiv
s7: difference
r25: reg
r26: reg
r27: reg
r28: reg
r29: reg
r30: reg
r31: reg
r32: reg
END haar;
library IEEE;
entity haar_tb is
end;
component haar
PORT (
clock : IN bit;
end component;
signal clock: bit;
signal clk: bit;
begin
uut: haar
in1 => in1,
in2 => in2,
in3 => in3,
in4 => in4,
in5 => in5,
in6 => in6,
in7 => in7,
in8 => in8,
out1 => out1,
out2 => out2,
out3 => out3,
out4 => out4,
out5 => out5,
out6 => out6,
out7 => out7,
out8 => out8 );
stimulus: process
begin
in1 <= 18;
in2 <= 5;
in3 <= 1;
in4 <= 9;
in5 <= 13;
in6 <= 6;
in7 <= 2;
in8 <= 3;
wait for 50ns;
in1 <= 10;
in2 <= 2;
in3 <= 3;
in4 <= 4;
in5 <= 15;
in6 <= 7;
in7 <= 13;
in8 <= 8;
wait for 50ns;
in1 <= 1;
in2 <= 3;
in3 <= 11;
in4 <= 8;
in5 <= 15;
in6 <= 4;
in7 <= 6;
in8 <= 13;
wait for 50ns;
wait;
end process;
clocking: process
begin
end loop;
wait;
end process;
end;
