test vector generating s/w..
angu
Member level 3
Member level 3
Hi Good Mrng to all...
Is there any software to generate test cases, test vectors for given digital circuit specification or functionality?
Thanx in advance
You can use PERL to generate test vectors for your testbench. PERL can also be used to automate your verification process.
vlsi_whiz,can you detail your method using Perl?
The detailed flow is ???
BR.
ls000rhb
perl is not a tool to generate test vectors. But perl would definitely help, if you know the design, if you know the verification method, and of course you will have to know how does your test vectors look like? It can only automate a processs if you know the logic, it cannot generate logic.
Kr,
Avi
http://www.vlsiip.com
Depending on your specification, some standards give you test codes. other standard you have to write your own C/Matlab code.
C++ fixed point -> HDL-> FPGA is a standard flow.
