kamiar.t
Member level 1
- Joined
- Sep 19, 2014
- Messages
- 35
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 202
what is the best simulator about simulating terahertz antenna?
Simulations tend to fail at frequencies >50 GHz
ok, you said that CST is unable simulating in terahertz frequencies?
for obtain a terahertz radiation we need to illuminate the substrate with a laser beam,No, I did not say that. CST is fine for THz frequencies.
how we can apply this laser beam in CST?
You asked about "simulating terahertz antenna". This does not require laser beam. You can use similar methods as known from GHz antenna simulations.
maybe it's true, because finally it's a current that will produce, thus maybe it's possible to use for example discrete port, but i saw that most of THz antenna simulated with another simulator, i can say i didn't saw any simulation THz antenna with CST or it's really few,(they use for example COMSOL, Silvaco, ...) because CST can't to model laser pulse.The THz antenna simulations that I saw used wave ports or discrete ports. No laser, all electronic.
If you want to do optical simulations, have a look here:
https://www.cst.com/Applications/Category/Optical-Devices
