temperature sweep in pspice
ehsantech
Member level 3
Member level 3
Hello
It is possible we do temperature sweep in pspice in a define range of numbers?for example 0 to 100?
Thanks
hi,
I use LTSpice which uses .step param temp 0 100 10 as a Spice Directive
It steps Tempr from 0C thru 100C in 10C steps.
E
Here's the PSpice syntax:
.DC TEMP  0 100 10
If you want to do only temp analysis do following -
.DC LIN TEMP 0 100 10
This would show x-axis as temperature.
If you want to do temp analysis along with any other analysis (tran, AC,DC sweep), specify following along with the other analysis -
.STEP LIN TEMP 1 100 10
This would create different sections and your x-axis would be (time,freq,DC voltage) depending on the type of analysis you choose. The sections would have the temerature variations.
