temperature impact on CMOS folded cascode op amp
tia_design
folded cascode op
I designed a folded cascode op amp, when doing simulation for different temperature, I found big difference for different temperature. I never did this before, so generally how to analysis it? What is the impact of temeprature on op amp performance?
constant gm input folded cascode
which spec is changed at different temperature in your design? The temperature will change the gain and GBW
cmos op amp, temperature
The process is not good.
To overcome the temperature dependence, it's better to adopt the constant-gm design.
Generally speaking, the cmos opamp's performance influenced by temperature will not so large either biased with constant or ptat current.
The transconductance of the input diff pair will vary with temperature. If this is a concern, you should bias it with a current source that will result in a constant gm. See page 248 of Analog Integrated Circuit Design by Johns and Martin
The gm of input pair varies within 2 from -25 to 125 degC, so the DC gain
should have 6dB difference regarding gm variaton.
check your dc point, maybe some transistors have been in triode.
I think the gm of input pair varies √2 rather 2.
Gds is not varied with temp much. So get the picture?
