Tackling DFM issues by designers
ameed
Full Member level 1
INDIA
hi all,
For a small Full custom design, a designer who is fully aware of the DFM issues can do his bit to increase the yield. But finally in a big chip design the designer has to be dependent on the EDA tools to do this.:D
Most of the EDA companies have come out with tools which take care of these DFM issues. But the universal success of such tools is still unknown!!
I think with other constraints taking priority over DFM issues, designers at this moment are not really worried about such problems. That is why fixing the DFM issues is "optional" and not "mandatory" at this moment.
But to survive in this competent market , soon DFM issues would be on a higher priority.:D
thanx.
DFM issue
ameed I agree with u.
The Layout designer should take care of DFM.
It is very important of following points:
Yield
Performance
and
life time of chip.
It is slightly increase area and no of chips per wafer is reduce 10% but performance is 99% good.
DFM is very big issue in VLSI.
Re: DFM issue
DfM: Design for Manufacturing or Design for Manufacturability: methodology which, when applied to microelectronics, permits to improve the yield/robustness of integrated circuits, taking into account the constraints of manufacturing in the early design phases.
The DfM Guidelines are a set of recommendation for designers.
These guidelines are defined for a given process of a given technology and are highly influenced by the materials, equipment, settings.
As a consequence, the DfM guidelines are based on the engineering judgment of process experts (often using the parametric test results of layout process structures on advanced reticles).
These guidelines are also discussed and reviewed with design experts.
For the 65 nm guidelines for expl , experts from the following areas have participated:
• Back-End process
• Front-End process
• Yield enhancement
• eDRAM design
• Full Custom design
• IO design
• SoC design
• Std cells design
• SRAM/ROM design
LaTeX Commands Quick-Menu:
