tachometer with optical sensor
emperio
Newbie level 3
mumbai
i have to use 89C2051 micro-controller.
pls help with this. we have to measure speed of rotating shaft and measure it using uc.
display it on lcd...
pls reply people as early as poss...
Ok this is your project so you start working on it and then ask questions if you have an issue that you cannot solve.
actually i have searched for prpojects and found the required one. the only problem i am facing is the micro-controller used is 89C52 instead of 89C2051. however it is mandatory for us to use the uc mentioned later.
so can you pls tell me wht r the changes to be done....
pls reply as early as poss... we have to start the project soon.
