mmoctar
Member level 4
environment variables were not found systemc
I'm begginner with systemc, try to use it with vc++ 2008. I build the Systemc and now I want to try an example but all time I get this error. This is my build log:
Build started: Project: fir, Configuration: Debug|Win32
Command Lines
Build machine environment variables may not be correct.
Creating temporary file "c:\systemc-2.2.0\examples\sysc\fir\Debug\RSP00000123083452.rsp" with contents
/Od /I "\..\src" /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "NOGDI" /D "_VC80_UPGRADE=0x0710" /D "_MBCS" /Gm /EHsc /RTC1 /MTd /Fo"Debug\\" /Fd"Debug\vc90.pdb" /W3 /c /ZI /TP /vmg
".\stimulus.cpp"
".\main_rtl.cpp"
".\main.cpp"
".\fir_fsm.cpp"
".\fir_data.cpp"
".\fir.cpp"
".\display.cpp"
Creating command line "cl.exe @"c:\systemc-2.2.0\examples\sysc\fir\Debug\RSP00000123083452.rsp" /nologo /errorReportrompt"
Output Window
Compiling...
display.cpp
c:\systemc-2.2.0\examples\sysc\fir\display.cpp(36) : fatal error C1083: Cannot open include file: 'systemc.h': No such file or directory
fir.cpp
c:\systemc-2.2.0\examples\sysc\fir\fir.cpp(36) : fatal error C1083: Cannot open include file: 'systemc.h': No such file or directory
fir_data.cpp
c:\systemc-2.2.0\examples\sysc\fir\fir_data.cpp(36) : fatal error C1083: Cannot open include file: 'systemc.h': No such file or directory
fir_fsm.cpp
c:\systemc-2.2.0\examples\sysc\fir\fir_fsm.cpp(36) : fatal error C1083: Cannot open include file: 'systemc.h': No such file or directory
main.cpp
c:\systemc-2.2.0\examples\sysc\fir\main.cpp(36) : fatal error C1083: Cannot open include file: 'systemc.h': No such file or directory
main_rtl.cpp
c:\systemc-2.2.0\examples\sysc\fir\main_rtl.cpp(36) : fatal error C1083: Cannot open include file: 'systemc.h': No such file or directory
stimulus.cpp
c:\systemc-2.2.0\examples\sysc\fir\stimulus.cpp(36) : fatal error C1083: Cannot open include file: 'systemc.h': No such file or directory
Generating Code...
Project : warning PRJ0018 : The following environment variables were not found:
$(SYSTEMC)
Results
Build log was saved at "file://c:\systemc-2.2.0\examples\sysc\fir\Debug\BuildLog.htm"
fir - 7 error(s), 0 warning(s)
Command Lines
".\stimulus.cpp"
".\main_rtl.cpp"
".\main.cpp"
".\fir_fsm.cpp"
".\fir_data.cpp"
".\fir.cpp"
".\display.cpp"
Output Window
Compiling...
display.cpp
fir.cpp
fir_data.cpp
fir_fsm.cpp
main.cpp
main_rtl.cpp
stimulus.cpp
Generating Code...
$(SYSTEMC)
Results
