synthesizable delays...
raja1982y
Newbie level 5
Newbie level 5
India
I am new to this group. I am new to design.
How can i design a module that consists of synthesizable delays. For example after assertion of "en" signals wait 2,3 or 4 clock cycles and then assert "strobe" signal. The delays are programmable. How can introduce the synthesizable delays between "en" and "strobe" signals.
Thanks,
Raja.
u can use a counter to count the number of cycles desired and then assert or deassert the required signals.
No delays like #3 or wait are synthesizable.
if i have so many signals with different delays then there will be so many counters. If i synthesize the code there will be so many counters created. what about the performance of the module?
Thanks.
You need just one counter, preferably a counter that counts down instead of up. Then load your 'programable' delay value in this counter then, let it count down until it reaches 0. At 0 value, assert your strobe.
Hope it helps, let me know if it works for you, if not, then time permitting, I may be able to do a small code for you
Kr,
Avi
http://www.vlsiip.com
Is counters is the only way or there any other methods for implementing the synthesizable delays?
-Rj
Yes, Counter is the only way you are going to accomplish it.
