Synthesis & STA: clock network timing definitions
ivlsi
Advanced Member level 3
Hello All,
How a clock timing should be defined during synthesis/STA? I mean skew/uncertainty/latency parameters. Should they be defined differently for the BC and WC checks?
Thank you!
Actually while setting the uncertainty value there is option -max and -min by which u can specify wc and bc respectively.
Reactions: ivlsi
    ivlsi
What's about input/output delays? Do they also have min/max definitions?
If you are using PT tool , then its better to use " man " command followed by required command to get whole information about it. It would be more accurate , with all options and how / where to use commands.
