I have to design a digital hardware block to synchronize a slower data rate from a network to a processor(working at higher data rate)...how should I go about the design ? should i use a PLL for this purpose ?
or use a asynchronous fifo (address should be gray coded)
best regards
Using the Asynchronous FIFO is the best option by having some handshaking signals as every time the fast data rate should not wait for slower data rate while reading
