Register Log in
Synchronize comparator output with a clock
iaf
Member level 3
I have a comparator which has a certain output for a microcontroller reset which i want to synchronize with the system clock so that it rises only when the edge of the clock rises and not earlier, what would be the easiest way to realize that?
srizbf
Advanced Member level 5
whatabout a clocked D-FF with D input from comparator out and clock from your source?
KlausST
Super Moderator
Staff member
there are ready to buy comparators with internal latched or clocked ouptuts.
Two examples:
* latched: MAX961
* clocked: HMC874
You need to provide a more detailed specification
Klaus
iaf
Member level 3
I'm designing it as an integrated circuit. I have tried a D-FF but it seems that's not delivering the required output
That's the simulation result, the output seems to be somehow affected by the clock, i can't the see the fault though
d123
Would an AND gate/ANDing clock signal and comparator high signal to the microcontroller reset pin work?
barry
California, USA
Well, that doesn't look right. And what do you mean "the output seems to be somehow affected by the clock"? It's SUPPOSED to be affected by the clock! Can you look at the outputs of I5, I7 and I4 and see if those are behaving properly?
Toggle Sidebar
