kgl_13gr
Member level 5
suzaku-v
I have the Suzaku-V board with the V2P FPGA. The board comes together with code that implements the minimum connections between the PowerPC on the FPGA and the other external components on the board so as to create a system that is able to run Linux. In order to use this predefined code you need to have Xilinx Platform Studio.
I don't have XPS and I don't need either the PowerPC or the external components of the board (with the exception of the clock, the flash memory and the JTAG interface of course for the programming). I want to program and use the FPGA standalone with my own VHDL files to implement and use custom logic. I make thoughts although whether this could cause any problem with the other board components and the FPGA because in the manual it is stated:
"Be careful not to run the SUZAKU-V if incorrect data has been programmed into the FPGA or an error occurred during programming. Collision between signals and an FPGA external circuit component (including on-board components) or abnormal operation could cause heat generation, degradation or damage."
In my opinion there shouldn't be any problem, as the pins that are connected to the external components with my configuration will be simply not connected internally.
Does anyone of you have any experience with this particular board or can in any way help?
