surpantine route in PADS like delay tune in allegro
havi
Member level 3
surpantine route
hi everybody,
is there any command in PADS like delay tune in allegro PCB design.
thanks
havi
Re: surpantine route
It is not as easy as Allegro but you can do it. Go to your settings and use Blaze Router.
M
Go to Setup-Design rules-net- select a net -High speed and now see the parameters to be defined to obtaine a delay tune.
using delay tune allegro what propose using delay tune icon send details
hi raj
delay tune is mostly for matching the two signal ...or trace
hi sir
normal line and delay tune is what different is using any board
hi raj,
Delay tune routing is used to matching the timing ( negative and positive end timing) like differential pairs.
Hi.sir
i will create artwork is create file ok but when i will create nc drill file is ok when i will see the gerber prevue the the artwork file and drill file not match. plz send nc drill parameter setting using details .send soon
There is a way to do Serpentine routing in PADS which is pretty effective. I call it "Poor Man's Auto Router :)".. You need to do some mathematics in calculating the trace lengthy required to cater to the delay requirement (approximately 120pS per inch delay on FR-4). Divide the resultant length into the number of serpentine segments that you can accommodate in your PCB (say 8 segments, 10, 12 and so on). Route one segment in PADS, and Copy paste the same thing (Ctrl C.Ctrl V) the number of times you want the serpentine to repeat. This works perfectly fine and you have tight control on routing also. I have tried this method and it has worked well for me :)
Re: Hi.sir
hi, raazraj
Please try like this image . this image shows design units inch or mil. If you use design unit mm please choose metric option in output units and also formate set 5.5.
Please try this.
