Suggest me 20pF capacitors for a 5Mhz chip in 0.35um CMOS process
dsj_guilin
Junior Member level 1
Ireland
I want implement some 20pF capacitors in a chip which will operate at about 5MHz. What kind of capacitor should I use? Can anyone give me some references which talk about it.
Many thanks
Added after 1 hours 16 minutes:
And the process is 0.35um CMOS.
Capacitor on chip
It depends on what is important to you. You could pick the one with the smallest area, but that may have the highest stray capacitance to substrate. I assume you want floating capacitors? If so, you need to find out how much capacitance to substrate you can tolerate. Sandwich capacitors have a reasonable ratio of capacitance to stray - e.g. poly/Met1/Met2 sandwich with poly & Met2 connected.
Whose 0.35um process is it?
Keith.
Re: Capacitor on chip
Thanks Keith. I will use the TSMC 0.35um process.
Capacitor on chip
You can the capacitance of the transistor. Moscaps are very usefull and easy to implement.
Cheers,
Advares.
Before jumping with suggestions, the OP needs to clarify if he wants floating or not.
In generat, cap to ground -> moscap -> least area
floating -> need MIM, MOM or finger cap.
