PIC microcontroller is not getting started. I have made connection by copying my other board. Connections are seems to be fine. But i new board is not working at all.
If i replace the controller then controller works in OLD board, but not with new board.
Please post schematic of the new board / old board. Or the gerber/artwork files
Obviously, there have been errors made in copying your original board connections - but we cannot tell anything from this information. Are the GROUND pins connected to GND, and is at 0V?
if the same controller work in old board and not working in new board then must be some the think with new board designing or nay dry joint check out power pin voltage are proper are you using internal oscillator or external oscillator if external oscillator then please check the crystal or cap around the crystal.
