Stepper Motor Grounding required?
vaibhav.k
India
stepper motor ground
Hi friends
I have one ambiguity regarding grounding.
I have system in which power supply and CPU board is there.In CPU board there is stepper motor driver and display and other circuit is there.Supply for stepper motor is different from controller.
I had not merged Stepper motor driver ground to any ground on CPU.Stepper motor ground in grounded on Power supply board through inductor.
Is it correct or some different approch i should take
Please give me suggestion with some reference documents .
Thanks in advance
Vaibhav
pranam77
Advanced Member level 5
INDIA
Stepper Moror Grounding
If the driver section and the motor is using a separate supply and the both sections are separated by Opto's grounding both boards is not required.
    vaibhav.k
vaibhav.k
India
No
here both sections are not isolated by Optos
Its basically driven by L298
paurelian
Junior Member level 3
Europe
If the power supply of the digital part is different from the power supply of the motor and you are not using optos, then you have to connect both grounds together. The best place to connect it's a the stepper motor ground point. Try to avoid grounding loops and take care of the high current paths.
