dxtr
Member level 3
Hello everybody
In a power plant using Fuel Generators, I came across some technical things that I couldnt undertand
Well its a 4x2000KVA (4 generators 2000 KVA) , these 4 generators connected with Busbar to step-up transformers (410 V -> 11kV) , after that from the step-up transformer to HV cells switchgears and feeders to client.
The transformer are Y-D , the neutral in primary is grounded . and in the other side a homopolar generator is used to create neutral point wich is also grounded
My questions are :
1- Why the transfomer is not Y-Y in this case they would not buy and use homopolar generator ?
2- Why is it so important to ground neutral ?
3- What does the HV cells do exactly and what is INTERLOCKING ?
4- Why there is a resistor connected between 2 secondary phases at homopolar generator ?
thank you so much for your feedbacks
My questions are :
