Nov 22, 2006 #1 S soloktanjung Full Member level 6 Joined Nov 20, 2006 Messages 364 Helped 51 Reputation 100 Reaction score 43 Trophy points 1,308 Location nowhere Activity points 3,194 hi, i'm a little bit confuse on how to implement BIST in the design? from what i have read, i think that we insert BIST in the RT level. anyone can help? thanks in advance. hairo
Nov 24, 2006 #2 M mingcol Newbie level 5 Joined Aug 18, 2006 Messages 10 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,331 i know memory BIST can be accomplished using eda tools.
Nov 25, 2006 #3 S soloktanjung Full Member level 6 Joined Nov 20, 2006 Messages 364 Helped 51 Reputation 100 Reaction score 43 Trophy points 1,308 Location nowhere Activity points 3,194 so means that i've to find the tools for my project. thanks.
Nov 30, 2006 #4 J joe2moon Full Member level 5 Joined Apr 19, 2002 Messages 280 Helped 19 Reputation 38 Reaction score 7 Trophy points 1,298 Location MOON Activity points 3,717 BIST: Built-in self test Put the test circuit (test sequence control + pattern generator + result comparator) into the design. Yes. There are some tools support BIST insertion. --------------------------------------------------------------------------------- Memory BIST: --> http://www.logicvision.com/Products/Silicon_Test/Memory/Nanometer.shtml --> http://www.mentor.com/products/dft/memorytest/mbistarchitect/index.cfm --> http://www.mentor.com/products/dft/memorytest/macrotest/index.cfm Logic BIST: --> http://www.logicvision.com/Products/Silicon_Test/Logic/BIST.shtml --> http://www.mentor.com/products/dft/logicbist/lbist_architect/index.cfm ---------------------------------------------------------------------------------- OR You can wirte the RTL code of pattern generator according to the specific BIST algorithm. Tool just simplify the process and generate those RTL codes for you.
Dec 9, 2006 #5 S soloktanjung Full Member level 6 Joined Nov 20, 2006 Messages 364 Helped 51 Reputation 100 Reaction score 43 Trophy points 1,308 Location nowhere Activity points 3,194 thanx for the explaination. hairo
Jan 24, 2007 #6 H hgz Member level 3 Joined Feb 26, 2004 Messages 60 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 611 You can use tool, or you can write it yourself.
