FlyingDutch
Advanced Member level 1
- Joined
- Dec 16, 2017
- Messages
- 457
- Helped
- 45
- Reputation
- 92
- Reaction score
- 55
- Trophy points
- 28
- Location
- Bydgoszcz - Poland
- Activity points
- 4,960
some time ago I made attempt to connect very simple VGA CMOS camera sensor (OV7670) to FPGA board (Artix-7: XC7A100T-2FGG676I ). Here is link to this post:
https://www.edaboard.com/threads/how-to-connect-vga-cmos-camera-sensor-to-fpga-board.393473/
Now I would like to connect better camera sensor with full HD resolution (camera with parallel interface). In FPGA design with VGA camera the frame-buffer had been made in Block Memory (in FPGA chip), but for full HD resolution (1920x1080) the amount of BlockMemory in FPGA chip is too small. So I decided to look for external hardware solution.
I would like to use Static RAM memory in external IC placed on PCB board connected with FPGA board. I would like to use 12-bit color for pixel displayed on HDMI monitor ( my FPGA board has HDMI interface). The minimu amout of memory needed for frame-buffer (HD) is 2Mega X 16-bit word. It is also important the type of case of selected SRAM IC in order to I be able to design PCB and solder memory chip to board. Currently I selected such SRAM IC:
It is SRAM chip organized as 2048K words by 16 bits. The single power supply is 1.65V-2.2V. Case is 48-Pin TSOP ,TYPE I ( 12mm x 20mm ) which I should be able to solder to printed circuit board. Here is data-sheet for this SRAM memory chip ( IS61/64WV204816ALL ):
I am not sure if I had selected optimal IC for this purpose - I mean the ease of writing driver in VHDL/Verilog for such SRAM memory. I am also not sure if driving such asynchronous SRAM in synchronic way from FPGA board would be working properly. If somebody can give me hints for such project i Will be very grateful.
Thanks in advance and regards
IS61WV204816BLL-10TLI-TR ISSI - IC: SRAM memory | 32MbSRAM; 2Mx16bit; 2.2÷3.6V; 10ns; TSOP48; 61WV204816BL10TLIT | TME - Electronic components
ISSI IS61WV204816BLL-10TLI-TR | IC: SRAM memory; 32MbSRAM; 2Mx16bit; 2.2÷3.6V; 10ns; TSOP48 - This product is available in Transfer Multisort Elektronik. Check out our wide range of products.
www.tme.eu
