STATE TABLES...PLEASE HELP
SudsController
Newbie level 3
I am creating a state table for my final project to obtain my electronics degree. I am programming in assembly and was told by my professor that a state table can be some how be converted to assembly code. Can anyone tell me if this is true? If it is true is there somewhere in this forum I can be directed to that shows me how:?
Thank You
Yes, it can be converted. I can't give you a proof because it was well over 10 years when I took my computational theory class.
I recommend you to write first some pseudo, or real code in some easy to program high level language that does the equivalent of your state table, and then write your ASM code when you satisfied with the high level code. Depending on the CPU, there might be tricks applicable to the conversion.
