yadowman
Newbie level 1
ssram controller problem
i try to controll ssram... but my ssram controller works bad
my board is DE2-70, ssram model name is issi is61lps51236a
i write my verilog code....
module ssram_ctrl(input wire CLK_200, // clock
output reg [18:0] oSRAM_A, // address
output reg oSRAM_ADSC_N, // controller address status
output reg oSRAM_ADSP_N, // processor address status
output reg oSRAM_ADV_N, // burst address advance
output reg [3:0] oSRAM_BE_N, // byte write enable
output reg oSRAM_CE1_N, // chip enable
output reg oSRAM_CE2, // chip enable
output reg oSRAM_CE3_N, // chip enable
output wire oSRAM_CLK, // out -> in ssram clk
input wire [7:0] SRAM_D_A, // SRAM_D_A
input wire [7:0] SRAM_D_B, // SRAM_D_B
input wire [7:0] SRAM_D_C, // SRAM_D_C
input wire [7:0] SRAM_D_D, // SRAM_D_D
output wire [7:0] OUT_A,
output wire [7:0] OUT_B,
output wire [7:0] OUT_C,
output wire [7:0] OUT_D,
inout wire [7:0] SRAM_DQ_A, // SSRAM DATA_A
inout wire [7:0] SRAM_DQ_B, // SSRAM DATA_B
inout wire [7:0] SRAM_DQ_C, // SSRAM DATA_C
inout wire [7:0] SRAM_DQ_D, // SSRAM DATA_D
output reg oSRAM_GW_N,
output reg oSRAM_OE_N, // output enable
output reg oSRAM_WE_N); // write enable
// -- SSRAM -- //
reg SRAM_D_en;
reg [7 : 0] SRAM_DATA_A;
reg [7 : 0] SRAM_DATA_B;
reg [7 : 0] SRAM_DATA_C;
reg [7 : 0] SRAM_DATA_D;
reg [7 : 0] SRAM_DATA_O_A;
reg [7 : 0] SRAM_DATA_O_B;
reg [7 : 0] SRAM_DATA_O_C;
reg [7 : 0] SRAM_DATA_O_D;
reg [3:0] state = 4'b0000;
assign oSRAM_CLK = CLK_200;
assign SRAM_DQ_A = (SRAM_D_en) ? SRAM_DATA_A : 8'bz;
assign SRAM_DQ_B = (SRAM_D_en) ? SRAM_DATA_B : 8'bz;
assign SRAM_DQ_C = (SRAM_D_en) ? SRAM_DATA_C : 8'bz;
assign SRAM_DQ_D = (SRAM_D_en) ? SRAM_DATA_D : 8'bz;
assign OUT_A = SRAM_DATA_O_A;
assign OUT_B = SRAM_DATA_O_B;
assign OUT_C = SRAM_DATA_O_C;
assign OUT_D = SRAM_DATA_O_D;
always @(posedge CLK_200)
begin
case (state)
0 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE1_N <= 1'b0;
oSRAM_CE3_N <= 1'b0;
oSRAM_CE2 <= 1'b1;
oSRAM_ADSP_N <= 1'b0;
oSRAM_ADSC_N <= 1'bX;
oSRAM_ADV_N <= 1'bX;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b1;
oSRAM_A <= 19'b0101010110101010110;
state <= 1;
end
1 : begin
SRAM_D_en <= 1'b1;
oSRAM_CE1_N <= 1'bX;
oSRAM_CE3_N <= 1'bX;
oSRAM_CE2 <= 1'bX;
oSRAM_ADSP_N <= 1'b1;
oSRAM_ADSC_N <= 1'b1;
oSRAM_ADV_N <= 1'b1;
oSRAM_BE_N <= 4'b0000;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b0;
oSRAM_OE_N <= 1'b1;
SRAM_DATA_A <= SRAM_D_A;
state <= 2;
end
2 : begin
SRAM_D_en <= 1'b1;
oSRAM_CE1_N <= 1'b1;
oSRAM_CE2 <= 1'bX;
oSRAM_ADSP_N <= 1'bX;
oSRAM_ADV_N <= 1'b0;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b0;
oSRAM_WE_N <= 1'bX;
oSRAM_OE_N <= 1'bX;
SRAM_DATA_B <= SRAM_D_B;
state <= 3;
end
3 : begin
SRAM_D_en <= 1'b1;
oSRAM_CE2 <= 1'bX;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b0;
oSRAM_WE_N <= 1'bX;
oSRAM_OE_N <= 1'bX;
SRAM_DATA_C <= SRAM_D_C;
state <= 4;
end
4 : begin
SRAM_D_en <= 1'b1;
oSRAM_CE2 <= 1'bX;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b0;
oSRAM_WE_N <= 1'bX;
oSRAM_OE_N <= 1'bX;
SRAM_DATA_D <= SRAM_D_D;
state <= 5;
end
5 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'b1;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
state <= 6;
end
6 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'bX;
oSRAM_BE_N <= 4'b1111;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b1;
state <= 7;
end
7 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
SRAM_DATA_O_A <= SRAM_DQ_A;
state <= 8;
end
8 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
SRAM_DATA_O_B <= SRAM_DQ_B;
state <= 9;
end
9 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
SRAM_DATA_O_C <= SRAM_DQ_C;
state <= 10;
end
10 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'b1;
oSRAM_ADSC_N <= 1'b0;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
state <= 11;
end
11 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'b0;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
SRAM_DATA_O_D <= SRAM_DQ_D;
state <= 0;
end
default : begin
SRAM_D_en <= 1'bX;
oSRAM_CE2 <= 1'bX;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'bX;
oSRAM_WE_N <= 1'bX;
oSRAM_OE_N <= 1'bX;
state <= 0;
end
endcase
end
endmodule
i wanna my code's wrong point... plz help me....
// -- SSRAM -- //
reg SRAM_D_en;
begin
case (state)
0 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'b1;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b1;
state <= 1;
end
1 : begin
SRAM_D_en <= 1'b1;
oSRAM_CE2 <= 1'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b0;
oSRAM_OE_N <= 1'b1;
state <= 2;
end
2 : begin
SRAM_D_en <= 1'b1;
oSRAM_CE2 <= 1'bX;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b0;
oSRAM_WE_N <= 1'bX;
oSRAM_OE_N <= 1'bX;
state <= 3;
end
3 : begin
SRAM_D_en <= 1'b1;
oSRAM_CE2 <= 1'bX;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b0;
oSRAM_WE_N <= 1'bX;
oSRAM_OE_N <= 1'bX;
state <= 4;
end
4 : begin
SRAM_D_en <= 1'b1;
oSRAM_CE2 <= 1'bX;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b0;
oSRAM_WE_N <= 1'bX;
oSRAM_OE_N <= 1'bX;
state <= 5;
end
5 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'b1;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
state <= 6;
end
6 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b1;
state <= 7;
end
7 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
state <= 8;
end
8 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
state <= 9;
end
9 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
state <= 10;
end
10 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'b1;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
state <= 11;
end
11 : begin
SRAM_D_en <= 1'b0;
oSRAM_CE2 <= 1'b0;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'b1;
oSRAM_WE_N <= 1'b1;
oSRAM_OE_N <= 1'b0;
state <= 0;
end
default : begin
SRAM_D_en <= 1'bX;
oSRAM_CE2 <= 1'bX;
oSRAM_BE_N <= 4'bX;
oSRAM_GW_N <= 1'bX;
oSRAM_WE_N <= 1'bX;
oSRAM_OE_N <= 1'bX;
state <= 0;
end
endcase
end
endmodule
