SSD1306 Dispaly any char,number
KVSN91
Junior Member level 2
hii..
I am dealing With SSD1306 Oled Display.I initiakized & enble and all is okThe display init, But i did not Understand How to Display dot(.),any Charecter & number
could u give me a sample code for me
If the display controller has no built in character set (dot pattern for each character), then you need to build it in your software.
Decide what dots needs to be active to show a character. Often there is a character set with 5 x 7 dots.
Then you have to decide where to place the "dots" on the display.
Klaus
    V
k sir , i did'nt understand how to write dot pattern to display... is there any example code for me to understand cliearly
Typing in "ssd1306 example code" at google gives me a lot of promising links, e.g. the adafruit libraries.
i am read some articles but i cann't understand .in some they are giving examples of fonts dispaly pics etc but i want display characters numebers using dots because is there any code for me
Dot matrix displays use fonts to display anything. You need to use fonts, too.
I tried most but i cann't display i am see more exmples i didnt understand how to do help me to how to display is there any code give me
hi sir, is there any code for i tried mostly i ann't display anything
The correct way is to reserve a memory window in RAM, draw a symbol there and after that upload it to LCD via fill widow method.
hi sir
i wrote my cod like this
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
void Init_Display(void)
    Dispaly();
    //Clear_Screen(0x00);
void Dispaly(void)
  RES=0;
  Delay(0xFFF);
  RES=1;
  Delay(0xFF);
  Write_Command(0xAE);    // Turn Off Display Panel
  Write_Command(0xA8);    // Set MUX Ratio
  Write_Command(0x3F);
  Write_Command(0xD3);    // Set Display Offset
  Write_Command(0x00);
  Write_Command(0x40);    // Set DisplayStart Line
  Write_Command(0xA1);    // Set Segment re-map
  Write_Command(0xC0);    // Set COM Output Scan Direction
  Write_Command(0xDA);    // Set COM Pins hardware configuration
  Write_Command(0x12);
  Write_Command(0x81);    // Set Contrast Control
  Write_Command(0x7F);
  Write_Command(0xD5);      // Set Osc Frequency
  Write_Command(0x80);
  Write_Command(0x8D);      // Enable charge pump regulator
  Write_Command(0x14);
  Write_Command(0xD9);          // Set Pre-charge Period
  Write_Command(0xF1);
   Set_Addressing_Mode(0x02);
  Write_Command(0xA4);      // Disable Entire Display On
  Write_Command(0xA6);      // Set Normal Display
  Clear_Screen(0x00);
  Delay(0xFF);
void Clear_Screen (unsigned char Data)
        unsigned char i,j;
            for(i=0;i<8;i++)
                Set_Start_Page(i);
                Set_Start_Column(0x00);
                for(j=0;j<128;j++)
                    Write_Command(Data);
void Set_Cursor(unsigned char X,unsigned char Y)
    Write_Command(0x0F & 0x00);
    Write_Command(0x0F & 0x10+(X>>4));
    Write_Command(0xB0+Y);
void Draw_Pixel(unsigned char x_pos, unsigned char y_pos, unsigned char colour)\
    unsigned char value = 0x00;
    unsigned char page = 0x00;
    unsigned char bit_pos = 0x00;
    page = (y_pos / y_max);
    bit_pos = (y_pos - (page * y_max));
    value = buffer[((page * x_max) + x_pos)];
    if((colour & 0x01) != 0)
        value |= (1 << bit_pos);
    else
        value &= (~(1 << bit_pos));
    buffer[((page * x_max) + x_pos)] = value;
    OLED_gotoxy(x_pos, page);
    //Write_Command(value, DAT);
    Write_Command(value);
when i am try to clear dots on dispaly is not cleared
dots means whole display filled with dots
sir i should not understand how to do, i am trying mostly thats why i am asking ,
How are you attempting to plot and clear the dots at the main() function ?
Sir ,
I trying clear display ,its not clear is like the attached picture
Now I am trying to clear the display like above. That's my problem.how to clear and how to display
y cod like this
Code C - [expand]
    Dispaly();
void Dispaly(void)
  RES=0;
  Delay(0xFFF);
  RES=1;
  Delay(0xFF);
  Clear_Screen(0x00);
  Delay(0xFF);
        unsigned char i,j;
            for(i=0;i<8;i++)
                Set_Start_Page(i);
                for(j=0;j<128;j++)
I wrote the code to clear like above but its look like above same
Help me how to clear how to display
You re-typed the same code posted before, still lacks the main() function that instantiate the functions above. We need to see how you're doing to call these routines.
By the way, the sequence of commands that you are using is a bit different from that suggested by the manufacturer, at the Application Note at page 64 of this document:
You don't show the actual code accessing the SSD1306 controller. There should be different functions to write command and data. I can't see it in your code.
