conmourtz
Member level 1
- Joined
- Mar 29, 2012
- Messages
- 36
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Volos, Greece
- Activity points
- 1,529
Hi there,
I have a design on Soc encounter. As you can see on the following attached files i have problem with pad vdd/vss power wiring on special route. i do the special route (i have 5 power signals for pads and 2 for core area). The 5th power siganl is only connected on the top of the design as you can see and on no other side of the design. Also, i tried put some more power pads on left, right and bottom and the same happened. No connection for the 5th power pad on left, right, bottom of the design. Secondly, when i do the nano route, the wires that connects the pads and the macro cells have some spacing problems as the violation report shows me. What could be wrong and how i can fix it? Please help me.
Best regards.
Best regards.
