FlyingDutch
Advanced Member level 1
- Joined
- Dec 16, 2017
- Messages
- 458
- Helped
- 45
- Reputation
- 92
- Reaction score
- 55
- Trophy points
- 28
- Location
- Bydgoszcz - Poland
- Activity points
- 4,983
I can't find differences between two SRAM Async memories (parallel) in their interface. In FPGA IpCores "Dual Port" RAM memories has two separate address and data ports. Could somebody explain me why these two example SRAM ICs are described as "Dual Port" or not. The first SRAM IC - "IS61WV102416FBLL-10T2LI-TR-ND" is desribed on Digi-Key web page as "Dual port" - see links:
https://www.digikey.pl/product-deta...T2LI-TR/IS61WV102416FBLL-10T2LI-TR-ND/8563776
http://www.issi.com/WW/pdf/61-64WV102416FALL-BLL.pdf
The second SRAM IC - "IS61WV204816BLL-10TLI " is not described as "Dual port" - see links:
https://www.digikey.pl/products/en/...Sort=0&page=1&stock=1&datasheet=1&pageSize=25
https://www.issi.com/WW/pdf/61-64WV204816BLL.pdf
When I am looking in their datasheets I can't find differences in address and data busses (the first IC hasn't two separate addres and data ports). Could somebody explain me why this first IC is described as "Dual Port" ?
Thanks in advance and Regards
