rieuwa
Newbie level 1
Hi all,
Thanks to this forum, I've been able to get started in HFSS and obtained some working simulations of a copper planar spiral inductor on polyimide.
I am simulating it in order to extract its inductance, series resistance and parasitic capacitance, for a near-field coupling application at frequencies ~1MHz. I have built inductors almost identical to my HFSS design and as such have a baseline value for what I believe these values should be (~8uH, Rs=1.5Ohms), with these values closely matching 'theoretical' calculations. I would really like to be able to corroborate these in simulation.
My question relates to the choice of airbox size- having been through many of the previous posts on the topic, the usual recommendation seems to be lamda/10 to lamda/4. Of course at freqs of 1MHz, this would result in an enormous airbox compared to my inductor. I have tried a wide range of sizes, and either the simulation never finishes (Execution Failure on Server usually) or the values are way off from measured ones.
However, if I run the simulation with an airbox which is just very slightly larger than the antenna size, the simulated values become very close to the measured ones.
Would appreciate any insights/suggestions from the community on my approach.
Many thanks!
rieuwa
My HFSS design: View attachment SpiralInductor15turnsNearField.zip
Many thanks!
rieuwa
