Spatial Scattering Parameters of Volume Loss Density in HFSS
dopplerjeff5000
Newbie level 5
Newbie level 5
Hi!
Does anyone know how to plot the scattering parameters or volume loss density over only a certain part of the simulation? I'd like to see in a complex simulation the areas where I'm losing the most power, and I'd like to be able to plot a frequency sweep of one section of the model versus another.
Thanks!
Hi dopplerjeff5000,
You'd have to do this manually, i.e. without using wave ports. What you need to do is insert surfaces over the areas that you are interested in, then use the fields calculator to integrate the Poynting vector over those surfaces. From the input and output surfaces as "ports", you can calculate the scattering or loss.
Good Luck
Thanks for the prompt and thorough reply. I will try what you suggest!
Hi dopplerjeff5000,
Good Luck
I have a similar simulation going on (plane wave excitaiton, and want to get the incident power going into the simulation and scattered off). I was trying to integrate the poynting vector at a boundary between a Pml and airbox where I have a plane wave excitation, but it doesn't seem to work. Does anyone have any tips for how this is done in HFSS. I can't get this to work in the field calculator.... It keeps saying "the stack contents are incompatible with the current operation". Although I can easily plot the poynting vector in HFSS at this boundary.
Hi PlanarMetamaterials,
Thanks for your quick reply! I think I managed to get it to solve (sort of), but now it is giving an answer that doesn't seem to make sense.
I am copying "Vector_RealPoynting" to the stack, then the interface in the geometry between the pml and airbox, then selecting "scalar z". Then, I am integrating and clicking "Eval". The result is a negative number -1.659x10-13!
When I plot the poynting vector in the model I can see the value is right around the expected value of 0.00133 W/m2. Correct me if I am wrong, but if the size of the interface is 0.005mX0.025m=.000125m2, then the power should be .000125m2 X .00133W/m2? See attached picture
Also, I should mention that I tried to do it with the "Normal" component selected as advised by the attached document, but it gave me the same answer (I guess that's expected to be the same). Seems weird that it's negative.... Is it because I did this at the pml/air boundary?
I am a chemist so I could easily be missing something! :-|
  • cookbook.doc
Hi eztucker,
That should give you the value at a specific point. You need to integrate the power over a sheet. Once you have the surface for geometry, select normal (to get power flowing through the surface), and then select integrate.
Hi eztucker,
Thanks for your help, really appreciate it! I just made a stupid mistake.....:oops: The geometry is in microns so it should be 1.25x10-10m2 and a few rounding errors skew it a little, but it now gives the expected results. I guess it's negative because the wave is traveling down (-z direction). Cheers.
ezt
