sparten 3e digital to analog
asraf
Junior Member level 3
hai there,
does anyone have experience with D/A on sparten 3e board? can u please guide me?
mrflibble
Advanced Member level 5
A more detailed post regarding your dac related problem would be helpful...
yadog
Member level 1
it's just a problem about writing a DAC driver
if u use a serial DAC,the task will be a little trouble
if u use a parallel DAC,u just give the DAC a clock and the data,then the DAC can work
asraf
i want to send the digital data to power amplifier.so i have to convert the digital data to analog using D/A technique. but i dont have any idea how to start with D/A in sparten 3e. the sparten 3e used SPI for D/A.i need some tips and help here.
yadog
Member level 1
the keypoint is quite clear.
u just need to write a SPI driver for the DAC,then the DAC can work!
So,just refer to the DAC's datasheet,find the control timing,implement the timing sequence
by ur code!
