Zhane
Member level 5
as Indicated on the userguide for Spartan 3E, they wrote for my XC3S500E Device,
Ram Column : 2
Ram Blocks per Column: 10
Total Ram Blocks: 20
Total Ram Bits: 368,640
Total Ram KBits: 360k
with the above in mind, does it mean that the Block-Ram FIFO i generate with the core generator,
for the Write Width of 8, can only set my Write Depth to 360k/8 at the maximum?
what happens if I set it to higher than 360k/8 for my Write Depth?
Ram Column : 2
