atuo
Member level 3
optimize_registers
1.how to set constraint on reset signal. I use 'set_ideal_network',and is it right?
2.how to set_max_fanout except clock and reset.
3.When I synthesis a module A the timing slack is small,but I put the module A into a top_level module B and sythesis the top_level module B,and the timing slack is very big. The inputs and outputs port of module A are all rigister,and I don't know why the two result are so different?
