satya_kola
- Joined
- Aug 19, 2012
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Hyderabad, India
- Activity points
- 1,362
Hi
i have code to to calculate pulse width. my code is working fine. I added a chipscop pro to my project.In of net connection window some net's are missing. I declared the output as pw : out STD_LOGIC_VECTOR(31 DOWNTO 0);
but in net connection window it is showing as below
pw_2 pw_2 FDE FDE
pw_3 pw_3 FDE FDE
pw_4 pw_4 FDE FDE
pw_5 pw_5 FDE FDE
pw_6 pw_6 FDE FDE
pw_7 pw_7 FDE FDE
pw_8 pw_8 FDE FDE
pw_9 pw_9 FDE FDE
pw_10 pw_10 FDE FDE
pw_11 pw_11 FDE FDE
pw_12 pw_12 FDE FDE
pw_13 pw_13 FDE FDE
pw_14 pw_14 FDE FDE
pw_15 pw_15 FDE FDE
pw_16 pw_16 FDE FDE
pw_17 pw_17 FDE FDE
pw_18 pw_18 FDE FDE
pw_19 pw_19 FDE FDE
pw_20 pw_20 FDE FDE
pw_21 pw_21 FDE FDE
pw_22 pw_22 FDE FDE
pw_23 pw_23 FDE FDE
pw_24 pw_24 FDE FDE
pw_25 pw_25 FDE FDE
pw_26 pw_26 FDE FDE
pw_27 pw_27 FDE FDE
pw_28 pw_28 FDE FDE
pw_29 pw_29 FDE FDE
pw_30 pw_30 FDE FDE
pw_31 pw_31 FDE FDE
My pw_0 and pw_1 are missing.
and i am unable to synthesis the code some errors are coming. when i synthesis the code without chipscope pro it is fine
error message are
ERROR
ack:679 - Unable to obey design constraints
(MACRONAME=U_ila_pro_0/U0_I_NO_D.U_ILA/U_TRIG/U_TM/G_NMU[0].U_M/U_MU/I_MUT_GA
ND.U_match/I_SRL16.U_GAND_SRL16_MSET, RLOC=X0Y3) which require the
combination of the following symbols into a single SLICEM component:
Shift symbol
"U_ila_pro_0/U0/I_NO_D.U_ILA/U_TRIG/U_TM/G_NMU[0].U_M/U_MU/I_MUT_GAND.U_match
/I_SRL16.U_GAND_SRL16/I_TWMOD8_NE0.I_YES_RPM.I_SRLT_EQ_2.U_SRLH" (Output
Signal =
U_ila_pro_0/U0/I_NO_D.U_ILA/U_TRIG/U_TM/G_NMU[0].U_M/U_MU/I_MUT_GAND.U_match/
I_SRL16.U_GAND_SRL16/sel<31>)
Shift symbol
/I_SRL16.U_GAND_SRL16/I_TWMOD8_NE0.I_YES_RPM.I_SRLT_EQ_2.U_SRLL" (Output
Signal =
I_SRL16.U_GAND_SRL16/sel<30>)
MUXCY symbol
/I_SRL16.U_GAND_SRL16/I_TWMOD8_NE0.I_YES_RPM.I_YES_MUXH.U_MUXH" (Output
Signal =
I_SRL16.U_GAND_SRL16/I_TWMOD8_NE0.I_YES_RPM.I_YES_MUXH.U_MUXH/O)
The function generator
I_SRL16.U_GAND_SRL16/I_TWMOD8_NE0.I_YES_RPM.I_SRLT_EQ_2.U_SRLL is unable to
be placed in the F position because the output signal doesn't match other
symbols' use of the F signal. The signal
I_SRL16.U_GAND_SRL16/sel<31> already uses F. Please correct the design
constraints accordingly.
in warning window some warnings are there
WARNING:NgdBuild:1012 - The constraint <INST: UniqueName:
________________________________++++++++++++__________________________________
WARNING:Xst:1293 - FF/Latch <count_0> has a constant value of 0 in block <pulse_measure>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1896 - Due to other FF/Latch trimming, FF/Latch <count2_0> has a constant value of 0 in block <pulse_measure>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <pri1_0> (without init value) has a constant value of 0 in block <pulse_measure>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <pw_0> (without init value) has a constant value of 0 in block <pulse_measure>. This FF/Latch will be trimmed during the optimization process.
Help me thanks in advance
pw_2 pw_2 FDE FDE
pw_3 pw_3 FDE FDE
pw_4 pw_4 FDE FDE
pw_5 pw_5 FDE FDE
pw_6 pw_6 FDE FDE
pw_7 pw_7 FDE FDE
pw_8 pw_8 FDE FDE
pw_9 pw_9 FDE FDE
pw_10 pw_10 FDE FDE
pw_11 pw_11 FDE FDE
pw_12 pw_12 FDE FDE
pw_13 pw_13 FDE FDE
pw_14 pw_14 FDE FDE
pw_15 pw_15 FDE FDE
pw_16 pw_16 FDE FDE
pw_17 pw_17 FDE FDE
pw_18 pw_18 FDE FDE
pw_19 pw_19 FDE FDE
pw_20 pw_20 FDE FDE
pw_21 pw_21 FDE FDE
pw_22 pw_22 FDE FDE
pw_23 pw_23 FDE FDE
pw_24 pw_24 FDE FDE
pw_25 pw_25 FDE FDE
pw_26 pw_26 FDE FDE
pw_27 pw_27 FDE FDE
pw_28 pw_28 FDE FDE
pw_29 pw_29 FDE FDE
pw_30 pw_30 FDE FDE
pw_31 pw_31 FDE FDE
error message are
ERROR
Shift symbol
Signal =
Shift symbol
Signal =
MUXCY symbol
Signal =
