[ARM] Some keil syntax questions
love_electronic
Member level 5
Member level 5
Hi
I wanna ask some basic questions regarding keil uvision syntax.
what are the functions of following statement
#define GPIOCONF(mode, cnf)	((cnf << 2) | (mode))
Is (cnf<<2) shifting 2 times here?
#define CONFMASKL(pin) ((u32)~(15 << (pin * 4)))
what this statement tells?
Those are normal macro definitions.
The first shift the value of 'cnf' 2 bits to the left making room for ORing in 'mode'. I would suppose that mode is in the range 0-3.
The second makes an inverted 32 bit unsigned integer mask of 4 bits dependent on the 'pin' value, range 0-7. Like pin=0: 0xFFFFFFF0, to pin=7: 0x0FFFFFFF
