some information regarding SPYGLASS
alpeshchokshi
Full Member level 2
San Jose, CA
hello friends,
i need the reference material or any link regarding
SPYGLASS tool which is used for ASIC verification?????
Thanks in advance
bansalr
Full Member level 3
SPYGLASS is a tool from Atrenta. U can search there website for demo also.
This tool is differebt from other code analysis tools.
It synthesizes the design then u can analyse for.
1. Cross Clock domain,DFT check, Synthesis check, Coding style and many more.
infact a better tool
spauls
Advanced Member level 2
SPYGLASS is now a days sign off tool for linting.
zhustudio
China
Yes. Spyglass is a tools for the code level checking. It looks like a lint tools. But I heard the new version spyglass can estimate the pr congestion. It is based on simple synthesis. It is a good tool to integrate all coding problem. But personally, I think all other tools such as DC and back end pnr tools can give you enough info to modify your code, if you take the warning seriously.
ivlsi
Advanced Member level 3
So, is it must or nice to have?
Is this a RTL Code Hand-Off Sign-Off tool?
mail4idle2
Full Member level 4
With the complexity of design and agressive schedules any issue found in Last stage is overhead.
If you find some issue at RTL level it is good.
So it is "MUST".
ivlsi
Sign-Off tool for RTL- thank you!
RCircuit
Member level 3
How much is spyglass license price?
mail4idle2
Full Member level 4
It is very costly for a single user. Generally corporates have a deal so it comes less for them.
ivlsi
mail4idle2, what's about negative hold constraints? do you familiar with it?
ivlsi
Please take a look at this post: https://www.edaboard.com/threads/269890/
As you could see there, input/output -min delays have negative values.
Could you please check whether the constraints are correct there?
Just click on the attached image there and it will be zoomed in.
Thank you!
ivlsi
What about hundreds of thousands? If you are curious ...
RCircuit
Member level 3
It seems too costly. I run spyglass from time to time for linting. But I dont think it is worthy so much.
