Solution to a molelsim warning
iman110
Newbie level 3
Dear friends,
i was faced with the following warning while simulating a large verilog code and i 'm seeking for solutions:
Warning: Design size of 32257 instances exceeds ModelSim ALTERA recommended capacity.
# This may because you are loading cell libraries which are not recommended with
# the ModelSim Altera version. Expect performance to be adversely affected.
moreover, How can we access to output waveform file in text or binary form?
Cheers
I guess you are working on started edition.
Still your design will be simulated but will take more hours to load as well as simulate.
Go for a license Modelsim edition, where you wont see this warning.
In modelsim vsim will be used to view the wave form.
