Soldering 42AWG Wires on a connector
jimmykk
Full Member level 2
Hi
I have 42 AWG Coax wires which i need to solder on Hypertac connector- HJ501133019 (Page10/224 Frame HJ Plug). 32 wires need to be soldered on this connector.
The inner conductor of these coax wires go to ES1 to ES32 pins (pinout of Hypertac connnector) as shown in picture below while outer conductor fro each wire need to be connected to GND pins(in green boxes).
So wondering what is the best possible solution for soldering here. As the wires are so thin, they don't get soldered properly and are prone to damage.
And soldering the outer conductors to GND pins is even bigger challenge here.
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
You might want to try the conductive epoxy or silver conductive pen. (The brand I once had was CircuitWorks.)
It's easier to clean up mistakes, whereas solder tends to get messy.
However the join is not as robust as solder. It may loosen over the years.
c_mitra
Advanced Member level 5
42 AWG can be tricky; I cannot make out without a magnifying glass!!
I suggest you can try solder paste, make a clamp out of thick paper. First solder the inner conductors and then in the next step solder the shield using a soldering iron.
LaTeX Commands Quick-Menu:
