I´m projecting a Board with a bit of capacitors SMT CASE A like in the PDF above:
The problem is that on ORCAD file don´t have the PIN of Cathode and Anode of the Capacitor. When i create the NET list and use on Power PCB occurs a error like:
*Not valid pin name for part type P
R9.1 C61.1 C19.P C33.1 C62.1 C63.1 C34.1 C36.1
Of course, C19.P don´t exist. But when i edit the part of C19 i don´t know with one (pin 1 or 2) i put in Cathode and Anode.
Does it have any standard, like pin 1 for Anode (+)? Can anyone help me?
only from the symbol in schematic, we should make decision of which pin is positive and negative , but in your case, better to check with the value of the cap, as always caps whichevey the value greater than 1 UF , are polarised, ans less than this are non-polarised
