[General] SMD Microcontrollers
Rebel_88
Newbie level 2
Newbie level 2
Hi everyone,
I'm here to ask you a simple question but i can't solve it correctly: how many kind of smd microcontroller I can use?
Is there a guide or an Index where i can find all with dimensions?
I'm asking that because i have found only QFP (Quad Flat Package) dimensions but i need a thin and short rectangular shape for my project but i'm in trouble.
Thank you for all who want answer.
bigdogguru
Administrator
Advanced Member level 7
Southwest, USA
What type of microcontroller are you seeking? Manufacture? Architecture, 8051, PIC, AVR, ARM, etc?
Datasheets of the specific microcontroller typically list the available packages for that specific model.
Rebel_88
Newbie level 2
Newbie level 2
Hi, thank you for your anwer.
The main problem is the shape now, but i prefer a PIC or AVR microcontroller. So if i can know all different shape i could choose the correct architecture.
Is not there a reference sheet where i can find general dimensions for those components?
bigdogguru
Administrator
Southwest, USA
Microchip offers the following tool to select a component:
Microchip Advanced Part Selector
You can specify the number of pins and other desired characteristics the tool will select the components which meet your specifications and display them on the right hand side under Search Results window as you select each component in the window the specifics, including the package type, are displayed below search results window. For example the PIC16F631 is available in the PDIP, QFN, SOIC, SSOP (20-pin) packages. You can then access the specific datasheet for the device which will provide detailed dimensions of the available package types.
Atmel also has a similar product selection tool for AVRs.
BigDog
hobbyckts
Advanced Member level 1
You will get controller in any SMD Package. You need to decide the package and the pins of the controller. So for drawing which you have asked for please provide the package and number of pins required. We will try to provide the drawings of the same.
